Zum Hauptinhalt wechseln
Lenovo IdeaPad FLEX 4-1580 Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad FLEX 4-1580 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Battery Replacement: Schritt 3, Bild 1 von 1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad FLEX 4-1580 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Battery Replacement: Schritt 5, Bild 1 von 1
    • The battery is completely removed, and can be replaced with a new battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Здравствуйте, нужны запчасти на Lenovo Flex 4-1580
1)задняя крышка!?
daria.kras.work@gmail.com - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,686
