Zum Hauptinhalt wechseln
Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement
Was du brauchst
  1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 4, Bild 2 von 2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 5, Bild 1 von 1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Fan: Schritt 6, Bild 1 von 1
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 7, Bild 1 von 1
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 8, Bild 1 von 1
    • Now the fan is completely removed.
  9. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Touchpad: Schritt 9, Bild 1 von 1
    • After battery is removed, you will move to the touchpad.
  10. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 10, Bild 1 von 1
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  11. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 11, Bild 1 von 2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 11, Bild 2 von 2
    • Remove all the screws holding the touchpad down.
  12. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Circut Board: Schritt 12, Bild 1 von 1
    • Once fan and battery are removed, you are finally able to fully access the circuit board.
  13. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 13, Bild 1 von 2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the touchpad cord from the circuit board using a nylon spudger.
  14. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 14, Bild 1 von 1
    • Then you will lift up the flap that holds these wires down.
  15. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 15, Bild 1 von 3 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 15, Bild 2 von 3 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 15, Bild 3 von 3
    • After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
  16. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 16, Bild 1 von 1
    • After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
  17. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: Schritt 17, Bild 1 von 1
    • The circuit board is completely removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 821
