Einleitung
If the mouse is unresponsive on the screen then there is a problem with your touchpad.
Was du brauchst
Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
Pop off the back panel using a plastic opening tool once all screws are removed.
Use the iFixit Opening tool to disconnect the battery from the circuit board.
When all screws are removed from the battery, carefully lift the battery up.
Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
Eine weitere Person hat diese Anleitung absolviert.
