Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: Schritt 1, Bild 2 von 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: Schritt 2, Bild 3 von 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Disconnecting the battery from the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a PH00 screwdriver to remove the 3x(M2x4mm) screws.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: Schritt 5, Bild 1 von 1
    • Ensure the replacement battery is right, then follow the steps backward to assemble everything.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 328
