Einleitung
Replacing the battery on the Lenovo Ideapad Flex4-1130 is a relatively simple task with minimal risk of damaging the device. The battery might need replacement if your device is unable to remain on for very long even after being fully charged.
Was du brauchst
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
Fast fertig!
Abschluss
