Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 4-1130 Motherboard Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove eleven 6mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove connector cable.
  10. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
Abschluss
Adrian Miranda
677 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 925
