Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
If you are experiencing a delay between touching the touchpad and actual movement of the mouse on screen or a complete lack of mouse movement, a touchpad replacement might be needed.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  5. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  6. Remove eleven 6mm screws.
    • Remove eleven 6mm screws.
  7. Lift up black flap on the ZIF connector and pull the ribbon cable out.
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Remove connector cable.
    • Remove connector cable.
  10. Remove one last connector cable.
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
  11. Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Lift up the black tab on the ZIF connector and pull the ribbon cable out.
  12. Remove three 8mm screws. Remove three 8mm screws.
    • Remove three 8mm screws.
  13. Push the touchpad outwards to remove it.
    • Push the touchpad outwards to remove it.
Abschluss
Adrian Miranda
677 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 8
Insgesamt: 308
