Einleitung
A Wi-Fi card replacement is a quick and simple task. If you are experiencing slow or intermittent internet connection a Wi-Fi card replacement might be in order.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  6. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  7. Remove one 5mm screw. Remove one 5mm screw.
    • Remove one 5mm screw.
  8. Remove the Wi-Fi card from the motherboard socket. Remove the Wi-Fi card from the motherboard socket.
    • Remove the Wi-Fi card from the motherboard socket.
Abschluss
Adrian Miranda
677 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 53
