Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 2 von 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S1-G6, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 1,631
