Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 1
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 7, Bild 1 von 3 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 7, Bild 2 von 3 Lenovo IdeaPad Flex 5 14ARE05 Cooling Fan Replacement: Schritt 7, Bild 3 von 3
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
Abschluss
Michael Souza
135 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-6, Konn Fall 2024 Mitglied von UMass Dartmouth, Team 1-6, Konn Fall 2024
UMASSD-KONN-F24S1G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 108
