Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1470 Display Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1470 Display Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: Schritt 3, Bild 1 von 3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: Schritt 3, Bild 2 von 3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  4. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  5. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
  6. Lenovo IdeaPad Flex 5-1470 Display Replacement, Display: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws from the left and right hinges (two screws on each hinge).
  7. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 7, Bild 1 von 3 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 7, Bild 2 von 3 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the display assembly from the rest of the device by separating the hinges of the display from the body of the laptop.
    • Use a spudger to carefully pry loose the two screw covers (one on each hinge).
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws from the display (one on each side).
  8. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 8, Bild 2 von 2
    • Use a heat gun or an iOpener to lightly heat the outer edges of the display, loosening the adhesive strips.
    • Wedge a Jimmy or opening picks between the display and display housing, then carefully pry around the entire perimeter until the display separates from the housing.
  9. Lenovo IdeaPad Flex 5-1470 Display Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the display ribbon cable.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 11
Letzten 30 Tage: 63
Insgesamt: 586
