Einleitung
If you want to upgrade the SSD card in your Lenovo IdeaPad Flex 5-1470, use this guide to replace the SSD card. The SSD card in the Lenovo IdeaPad Flex 5-1470 is connected to the device’s motherboard.
Before replacing the SSD in your Lenovo IdeaPad Flex 5-1470, research which SSD cards are compatible with the device.
The only step to do before removing the SSD card is to remove the device’s back panel.
Was du brauchst
2 weitere Personen haben diese Anleitung absolviert.
