Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1470 Speaker Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
Abschluss
Ryan Beste
141 Reputation
1 Anleitung geschrieben
Cal Poly, Team S2-G5, White Winter 2020 Mitglied von Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,019
