Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  7. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  8. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Fan: Schritt 8, Bild 1 von 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  9. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  10. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 10, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  11. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Heatsink: Schritt 11, Bild 1 von 1
  12. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 12, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 12, Bild 2 von 2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
  13. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: Schritt 13, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: Schritt 13, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: Schritt 13, Bild 3 von 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 14, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 14, Bild 2 von 2
    • Using your hands, gently pull the left speaker up and out of the device.
  15. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 15, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 15, Bild 2 von 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  16. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Motherboard: Schritt 16, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 17, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 17, Bild 2 von 2
    • Disconnect the auxiliary port cable from the motherboard.
  18. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 18, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 18, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 18, Bild 3 von 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  19. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 19, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 19, Bild 2 von 2
    • Disconnect the display cable from the motherboard.
  20. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 20, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 20, Bild 2 von 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  21. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 21, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 21, Bild 2 von 2
    • Carefully lift and remove the motherboard from the device.
  22. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: Schritt 22, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: Schritt 22, Bild 2 von 2
    • Using the Phillips #00 screwdriver, remove the four total 5 mm screws from the left and right hinges (two screws on each hinge).
    • For proper screwdriver technique, please visit the Screwdriver Best Practices guide.
  23. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 23, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: Schritt 23, Bild 2 von 2
    • Disconnect the display assembly from the rest of the device.
Abschluss
Justin Ogihara
27.127 Reputation
52 Anleitungen geschrieben
EDU Team Mitglied von EDU Team
Staff
7 Mitglieder
637 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 100
Insgesamt: 4,290
