Einleitung
A hard drive is a data storage device using magnetic storage to recover digital data that appears in most laptops. The average lifespan of a hard drive ranges from 3 to 5 years. It may be replaced under the condition of a hardware failure or for upgrade of speed and capacity. This guide will show how will show you how to successfully replace the hard drive in the Lenovo IdeaPad Flex 5-1570.
Was du brauchst
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Use a spudger to pry open the back case at the two hinge cutouts.
Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
Remove the three 5 mm Phillips #00 screws that secure the hard drive.
Using your hands, gently pull the hard drive back, sliding it out from the port.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
