Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1570 RAM Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 3, Bild 2 von 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: Schritt 4, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: Schritt 4, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: Schritt 4, Bild 3 von 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: Schritt 6, Bild 3 von 3
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Blakely
19.506 Reputation
53 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
4 Kommentare
I've had a Lenovo Flex 5 for a number of years and it has been extremally reliable. I wasn't aware that upgrading anything on this unit was even possible. Thank you for this info, I'll be checking into this more.
John - Antwort
Please suggest what DDR4 RAM I should buy to replace it. I have a 16 GB, I want to go 32 or 64.
Maulik Darji - Antwort
"Patriot Viper Steel DDR4 32GB 2400MHz CL15 SODIMM Memory Module PVS432G240C5S" works on mine
Finality Video -
Thank you for posting this and especially to the commentor that posted the memory upgrade info. This has been a great laptop and I look for to extending the life of it with this upgrade.
Vee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 28
Letzte 30 Tage: 134
Insgesamt: 8,995
