Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 4, Bild 2 von 2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: Schritt 5, Bild 3 von 3
    • Remove the RAM from its slot on the motherboard.
Abschluss
Ein Kommentar
Thank you so much
Ayham Ka - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 33
Insgesamt: 703
