Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, SSD Card: Schritt 3, Bild 1 von 1
    • Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to gently pry up the protective cover off of the SSD card.
  5. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 5, Bild 1 von 1
    • The SSD card will spring up to one side on its own.
  6. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the SSD from the motherboard.
    • When reinstalling the SSD, push the SSD card back into its slot. The SSD card will click into place when it is secure and then rest at a 30 degree angle from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 689
