Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 6-14IKB Speakers Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Unplug the wire connector from the speaker using the tweezers.
  4. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: Schritt 4, Bild 2 von 2
    • Lift the right side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
  5. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: Schritt 5, Bild 1 von 1
    • Unwind the red and black wire that connects the two speakers from the plastic clips that secure it.
  6. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: Schritt 6, Bild 1 von 1
    • Lift the left side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 110
