Einleitung
If your RAM is insufficient or failing, you may want to replace or upgrade it by following this guide.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
Take your free hand and place it on the battery. Gently slide it away from its slot.
Rotate the laptop so that now the hinge is facing away from you.
Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
Slide the bottom panel towards you until it stops, and then carefully lift it off.
The RAM sticks can be found at the bottom right of the laptop.
Carefully press the two silver buttons on either side of the stick outwards. This will cause the RAM to “pop” up.
Ein weiterer Nutzer hat diese Anleitung absolviert.
