Ersatzteile
Kein Ersatzteil erforderlich.
  1. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Now push the right clip to the right and hold it while using your other hand to pull the battery out. Now push the right clip to the right and hold it while using your other hand to pull the battery out.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two screws highlighted.
    • Remove the two screws highlighted.
  5. This is the back of the laptop with the cover removed.
    • This is the back of the laptop with the cover removed.
  6. Now push the little clips out away from the memory to unlock the memory. Now push the little clips out away from the memory to unlock the memory.
    • Now push the little clips out away from the memory to unlock the memory.
  7. After unlocking the memory from it's position, pull the memory out.
    • After unlocking the memory from it's position, pull the memory out.
Abschluss
Christopher
666 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-7, Regan Spring 2014 Mitglied von Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 477
