Zum Hauptinhalt wechseln
Lenovo IdeaPad S10-2 Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Abschluss
Anthony
258 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 1-7, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 9,500
