Einleitung
Replacing the keyboard on your laptop can be necessary if your keyboard is no longer responding. You will need a nylon or metal spudger. Make sure that the power is off before continuing.
Was du brauchst
Rotate the laptop so the back side is facing you.
From this side, you should be able to see both of the gaps where the two plastic materials meet.
Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
Open the laptop.
Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
Pull up on the loose component to remove.
As you lift the keyboard, you should be able to see a strip connected to the laptop.
Remove the strip by pulling both sides of the blue strip out.
Lift and remove the keyboard from the laptop.
2 weitere Personen haben diese Anleitung absolviert.
