Zum Hauptinhalt wechseln
Lenovo IdeaPad S145-14IWL Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the ten screws that secure the lower case.
    • Insert an opening tool into the gap between the lower case and chassis.
    • Pry around the perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  2. Lenovo IdeaPad S145-14IWL Battery Replacement, Lenovo IdeaPad S145-14IWL Battery Disconnection: Schritt 2, Bild 1 von 1
    • Use angled tweezers to gently pull the battery connector directly out of its socket.
  3. Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the screws securing the battery.
    • Lift the battery up and out of the chassis.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting.
3 weitere Personen haben diese Anleitung absolviert.
LandonF
443 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 41
Insgesamt: 362
