Einleitung
This guide with show you how to replace the display on the Lenovo IdeaPad S145-14IWL. Use this guide to replace your screen if it is damaged, scratched or broken.
Was du brauchst
Use an opening pick to pry off bezel.
Use a Phillips #1 screwdriver to remove the four screws that secure the display.
Use an opening tool to pry off the hinge cover.
Use a Phillips #1 screwdriver to remove the screws securing both of the hinge brackets.
Use tweezers to peel back the tape over the display connector.
Lift the display connector locking bar.
Disconnect the display cable connector.
Lift the display assembly up and out.
