Zum Hauptinhalt wechseln
Lenovo IdeaPad S145-14IWL Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the ten screws that secure the lower case.
    • Insert an opening tool into the gap between the lower case and chassis.
    • Pry around the perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  2. Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Lenovo IdeaPad S145-14IWL Battery Disconnection: Schritt 2, Bild 1 von 1
    • Use angled tweezers to gently pull the battery connector directly out of its socket.
  3. Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the screws securing the battery.
    • Lift the battery up and out of the chassis.
  4. Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Lenovo IdeaPad S145-14IWL Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Flip up the black ZIF locking flap that secures the hard drive ribbon cable.
    • Disconnect the ribbon cable.
    • Use a Phillips screwdriver to remove the screws that secure the hard drive.
    • Remove the hard drive.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting.
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 372
