Zum Hauptinhalt wechseln
Lenovo IdeaPad S145-14IWL RAM Replacement
Was du brauchst
  1. Lenovo IdeaPad S145-14IWL RAM Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo IdeaPad S145-14IWL RAM Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo IdeaPad S145-14IWL RAM Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the ten screws that secure the lower case.
    • Insert an opening tool into the gap between the lower case and chassis.
    • Pry around the perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  2. Lenovo IdeaPad S145-14IWL RAM Replacement, Lenovo IdeaPad S145-14IWL Battery Disconnection: Schritt 2, Bild 1 von 1
    • Use angled tweezers to gently pull the battery connector directly out of its socket.
  3. Lenovo IdeaPad S145-14IWL RAM Replacement, RAM: Schritt 3, Bild 1 von 3 Lenovo IdeaPad S145-14IWL RAM Replacement, RAM: Schritt 3, Bild 2 von 3 Lenovo IdeaPad S145-14IWL RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • The RAM module will flip up slightly; this is normal.
    • Pull the RAM module directly out of its socket.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting.
Eine weitere Person hat diese Anleitung absolviert.
LandonF
443 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 314
