Zum Hauptinhalt wechseln
Lenovo IdeaPad S210 Touch Back Panel Replacement
Was du brauchst
  1. Lenovo IdeaPad S210 Touch Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: Schritt 5, Bild 3 von 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Abschluss
Zack Colman
885 Reputation
8 Anleitungen geschrieben
Ein Kommentar
Witam ile zatok część chce pan
Mikolaj Dabrowski - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 556
