Zum Hauptinhalt wechseln
Lenovo IdeaPad S400 Touch Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad S400 Touch Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo IdeaPad S400 Touch Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo IdeaPad S400 Touch Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 3 Lenovo IdeaPad S400 Touch Hard Drive Replacement, Hard Drive: Schritt 2, Bild 2 von 3 Lenovo IdeaPad S400 Touch Hard Drive Replacement, Hard Drive: Schritt 2, Bild 3 von 3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Hard Drive Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad S400 Touch Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 3mm Phillips #0 screws that hold the hard drive to the case.
    • Take out the hard drive by lifting and sliding it at the same time.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 1,060
