Zum Hauptinhalt wechseln
Lenovo IdeaPad S400 Touch RAM Replacement
Was du brauchst
  1. Lenovo IdeaPad S400 Touch RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch RAM Replacement, RAM: Schritt 2, Bild 1 von 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: Schritt 2, Bild 2 von 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: Schritt 2, Bild 3 von 3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch RAM Replacement: Schritt 3, Bild 1 von 1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch RAM Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad S400 Touch RAM Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad S400 Touch RAM Replacement: Schritt 4, Bild 3 von 3
    • Push the metal arms away from the RAM.
    • The RAM should pop up.
    • Pull the RAM out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 687
