Einleitung
If your Lenovo IdeaPad U310 is having problems with overheating, a broken fan may be to blame. This fan replacement guide will show you exactly how to replace it.
Was du brauchst
Flip the device over so the bottom panel is facing up.
Remove the rubber feet by pinching and pulling in an upward motion.
Place the plastic opening tool between the bottom panel and device.
Pry around the device's outer edge until the bottom panel is no longer attached.
Lift the bottom panel up and away from device.
Unplug the Battery from the circuit board by carefully prying the connector from its housing.
Remove the 5.6 mm Screw with the PH1 screwdriver.
Remove the 4.6 mm screws with the PH1 screwdriver.
Lift the strip tape away from the battery, being careful not to completely remove it.
2 weitere Personen haben diese Anleitung absolviert.
