Einleitung
Replacing the keyboard on your Lenovo IdeaPad U310 could seem tricky at first. Be sure not to apply too much pressure to the keyboard for this might damage the plastic casing, and use the proper opening tools.
Was du brauchst
Flip the device over so the bottom panel is facing up.
Remove the rubber feet by pinching and pulling in an upward motion.
Place the plastic opening tool between the bottom panel and device.
Pry around the device's outer edge until the bottom panel is no longer attached.
Lift the bottom panel up and away from device.
Unplug the Battery from the circuit board by carefully prying the connector from its housing.
Remove the 5.6 mm Screw with the PH1 screwdriver.
Remove the 4.6 mm screws with the PH1 screwdriver.
Lift the strip tape away from the battery, being careful not to completely remove it.
Remove the two 4.6 mm screws using PH1.
One is located next to the fan, the other at the corner of the battery.
Turn laptop upside down so the keyboard is facing up.
Place prying tool between the keyboard and the housing.
Move the prying tool around the keyboard's edge, releasing the tabs securing the keyboard.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Honestly, the best instructions for any task i ever made ⭐⭐⭐⭐⭐. Thank you
