Zum Hauptinhalt wechseln
Lenovo IdeaPad U310 Ram Replacement
Was du brauchst
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: Schritt 1, Bild 1 von 1
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: Schritt 2, Bild 1 von 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad U310 Ram  Replacement: Schritt 3, Bild 2 von 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: Schritt 4, Bild 1 von 1
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad U310 Ram  Replacement: Schritt 5, Bild 2 von 2
    • Continue to pry open the clips, and slip the RAM from its housing.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 2,528
