Einleitung
The keyboard is one of two primary input peripherals for most computers. In the event that it breaks, using a standalone USB keyboard can be a temporary solution before replacing it.
Was du brauchst
Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up.
Remove the battery unit from the laptop and set it aside.
Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
Flip the computer over and open the screen.
Use a spudger to carefully press in the clip that is found here while prying the keyboard upward from the same side.
Slightly lift the bottom of the keyboard towards the screen to locate the keyboard's ribbon cable.
Use the tip of the spudger to lift the black retaining flap on the ZIF connector.
You should now be able to lift out the keyboard easily.
Eine weitere Person hat diese Anleitung absolviert.
