Einleitung
RAM, or random access memory, is a form of computer data storage. RAM is used to quickly read and write data which the computer needs rapid access to. If a computer is running very slowly, it may not have enough RAM. In this scenario, the computer reads and writes to 'virtual RAM', also known as 'pagefile', on the hard drive. This is much slower.
Was du brauchst
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
Gently lift the back panel from the side closest to the battery and remove panel
Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
