Zum Hauptinhalt wechseln
Lenovo IdeaPad U350 RAM Replacement
Was du brauchst
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Lenovo IdeaPad U350 RAM Replacement: Schritt 2, Bild 1 von 1
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Lenovo IdeaPad U350 RAM Replacement: Schritt 3, Bild 1 von 1
    • Push retention clips outward and then gently slide out of slot
  4. Lenovo IdeaPad U350 RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove white and black wires to make room to remove the second RAM module.
  5. Lenovo IdeaPad U350 RAM Replacement: Schritt 5, Bild 1 von 1
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
Abschluss
James Morizzo
496 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-4, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 957
