Zum Hauptinhalt wechseln
Lenovo IdeaPad U410 Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad U410 Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad U410 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad U410 Battery Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad U410 Battery Replacement: Schritt 5, Bild 3 von 3
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Abschluss
Alysia Mcafee
107 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 828
