Was du brauchst
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
Pry the panel from the laptop using your hands or the metal spudger if necessary.
Lift the back panel away from you.
Locate the battery in the bottom right corner.
Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
Locate the small rectangle shaped connector to the left of your battery.
Use your fingers to gently detach the white connector.
