Einleitung
This guide will show you how to open the bottom panel on your Lenovo IdeaPad U410 using a Phillips #1 and metal spudger.
Was du brauchst
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
Pry the panel from the laptop using your hands or the metal spudger if necessary.
Eine weitere Person hat diese Anleitung absolviert.
