Einleitung
This hard drive replacement guide will show you how to properly remove the hard drive from your Lenovo IdeaPad. The only tool mandatory for this guide will be a #1 Phillips head screw driver and a metal spudger.
Was du brauchst
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
Pry the panel from the laptop using your hands or the metal spudger if necessary.
Use the Phillips #1 screwdriver to remove the three 3mm screws located on the rim of the hard drive.
Unscrew the four screws on either side of the hard drive with the Phillips #1 screwdriver.
Use your fingers and gently lift the hard drive from the case it was screwed into.
2 weitere Personen haben diese Anleitung absolviert.
