Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
Pry the panel from the laptop using your hands or the metal spudger if necessary.
Using your hands, gently press on the two clips parallel to the sides of the RAM.
Remove RAM from the laptop.
Ein weiterer Nutzer hat diese Anleitung absolviert.
