Einleitung
This screen replacement guide will show you how to replace your defective LCD screen on your Lenovo U410. You will need a Phillips #1 screwdriver and a metal spudger. Be careful when removing the plastic trim and connectors because you can easily break them.
Was du brauchst
Power off the laptop.
Using the metal spudger, gently pry off the black trim around the screen.
Lower LCD screen onto the keyboard.
Gently grab the connector on both sides and pull the connector straight out.
Eine weitere Person hat diese Anleitung absolviert.
