Einleitung
This guide will take 5 minutes and will require you to follow a prerequisite guide on how to remove the back cover. The solid state replacement will require a Phillips #1 screwdriver and a metal spudger.
Was du brauchst
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
Pry the panel from the laptop using your hands or the metal spudger if necessary.
Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
