Was du brauchst
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Disconnect charging port from motherboard.
To do this, press the spudger on the center dimple and push the connector out.
Pry the charging port out of the socket with a metal spudger.
It may be necessary to pry from each side.
Eine weitere Person hat diese Anleitung absolviert.
