Einleitung
This guide will take you through the steps to replace a broken or missing hard drive in the Lenovo IdeaPad U430 Touch
Was du brauchst
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
