Zum Hauptinhalt wechseln
Lenovo IdeaPad U430 Touch Speaker Replacement
Was du brauchst
  1. Lenovo IdeaPad U430 Touch Speaker Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 3, Bild 2 von 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Disconnect the speaker cable connectors from the motherboard and/or USB board.
  4. Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
  5. Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad U430 Touch Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove and replace the speaker.
Abschluss
USF Tampa, Team S2-G6, Nance Spring 2017 Mitglied von USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 551
