Was du brauchst
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Disconnect the speaker cable connectors from the motherboard and/or USB board.
Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
