Einleitung
This guide will walk you through the process of replacing an unresponsive or broken trackpad for the Lenovo IdeaPad U430 Touch.
Was du brauchst
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
Remove the two 2.8 mm screws attached to the trackpad using the Phillips #1 screwdriver.
Detach the zif ribbon labeled "TP" and "MB" at the "MB" end.
