Einleitung
A Wifi card is the component that connects your computer to wireless networks. In the case of a Wifi Card failure this is how to replace it.
Was du brauchst
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Remove the two snap cables connecting the wifi card to the rest of the computer.
