Zum Hauptinhalt wechseln
Lenovo IdeaPad U450 Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad U450 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Fan Replacement: Schritt 2, Bild 1 von 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Fan Replacement: Schritt 3, Bild 1 von 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Fan Replacement, Top Panel: Schritt 5, Bild 1 von 1
    • Turn the laptop over so that the bottom is facing up.
  6. Lenovo IdeaPad U450 Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove all 7mm phillips head screws using the Phillips #00 screwdriver.
  7. Lenovo IdeaPad U450 Fan Replacement: Schritt 7, Bild 1 von 1
    • Turn the laptop over again and open the laptop.
  8. Lenovo IdeaPad U450 Fan Replacement: Schritt 8, Bild 1 von 1
    • Gently lift up the top panel utilizing the hole where the battery would be.
    • Keyboard ribbon cable is still connected. Flip the ZIF connector up and remove the ribbon cable.
  9. Lenovo IdeaPad U450 Fan Replacement: Schritt 9, Bild 1 von 1
    • Disconnect any wires that are connected to the top panel from the bottom of the laptop.
  10. Lenovo IdeaPad U450 Fan Replacement, Fan: Schritt 10, Bild 1 von 1
    • Unplug the bundled fan connector from the motherboard.
  11. Lenovo IdeaPad U450 Fan Replacement: Schritt 11, Bild 1 von 1
    • Unscrew all screws that hold the fan down using the Phillips #00 screwdriver.
  12. Lenovo IdeaPad U450 Fan Replacement: Schritt 12, Bild 1 von 1
    • Remove the fan from the slot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Anna Church
146 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S7-G1, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S7-G1, Julie Spring 2017
UMASSD-JULIE-S17S7G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 389
